Pedal shaft stuck
I'm trying to take the pedals off of a Puch and I can't get the bolt out of the pedal shaft to remove them. I've had this problem before and I wasn't able to solve it then either. I've tried pb blaster, etc. and nothing seems to help. It seems really stuck and I don't want to damage it. Any suggestions would be appreciated.
Re: Pedal shaft stuck
Kaj Niegmann /
Thread the bolt back on and hit it will a hammer, a copper tipped one if you have it. With the bolt threaded on flush it should protect the threads.
If you mean the cotter pin on the pedal arms, put the nut back on, loosen 1 turn and put a 6mm socket on top of the nut to protect the threads and give it a goodly whack with a hammer. That way you are only sending the hammer shock through a short length of the threaded part rather then the whole length which usually smashes the threaded part without shifting the fastener.
That worked perfectly. Thanks guys.
