Disc Brake piston stuck
I accidentally pulled on the brake when the calipers were off the rotor. I had to take the pads off and squeeze the piston back with a C clamp. Now, when I reassembled it, the piston won't move.
Any ideas?
I disconnected the hose and put more fluid in the reservoir, and it squirted out when I squeezed the lever. So I know that at least it's pumping fluid thru the hose. When I connect the hose to the caliper, the lever doesn't build up any resistance. ???
Re: Disc Brake piston stuck
Lukas McWhorter /
The piston probably got all cock eyed in the bore. Best I can tell you is to remove the piston, LIGHTLY hone the caliper bore and put the piston back in using new seals.
Zachary Michael /
Yep. Time to get out that ole honing tool you've been wanting to use.
