Dumb 73 Vespa Ciao questions
Garrett Sterling /
I found a 73 Vespa Ciao(chrome fenders, front suspension, NO TURN SIGNALS)
Im not familiar with these. It looks like it has a horn switch on the right grip, and a black pointer switch ontop of the headlight assy.
Is the black pointer switch an on off for the light or a hi/low beam?
Where is the run/off switch? I have been reading about the decomp lever and all that but how do you shut these mopeds down after its running?
I know the key is just a fork lock from what I understand.
LASTLY(thanks for your patience), I have two wires coming through the frame toward the rear of the bike. Both come out of the main harness from headlamp assy. One I can see obviously hooks up to the tail light/brake light assy, the other is grey sheathed as well with what looks like a single white wire inside and has been cut and hanging out of the frame under the rear fender so I cant tell what it went to. What the heck is this one for as I cannot tell from wiring diagrams Ive looked at.
Thanks for your help!
