Dumb 73 Vespa Ciao questions
Garrett Sterling /
I found a 73 Vespa Ciao(chrome fenders, front suspension, NO TURN SIGNALS)
Im not familiar with these. It looks like it has a horn switch on the right grip, and a black pointer switch ontop of the headlight assy.
Is the black pointer switch an on off for the light or a hi/low beam?
Where is the run/off switch? I have been reading about the decomp lever and all that but how do you shut these mopeds down after its running?
I know the key is just a fork lock from what I understand.
LASTLY(thanks for your patience), I have two wires coming through the frame toward the rear of the bike. Both come out of the main harness from headlamp assy. One I can see obviously hooks up to the tail light/brake light assy, the other is grey sheathed as well with what looks like a single white wire inside and has been cut and hanging out of the frame under the rear fender so I cant tell what it went to. What the heck is this one for as I cannot tell from wiring diagrams Ive looked at.
Thanks for your help!
Re: Dumb 73 Vespa Ciao questions
Black buttons the horn
Headlight switch on/off
There is no kill switch. De-comp can be used to kill the engine + chocking it or covering your air box(or all 3)
The 3 wires should be taillight, brake light and a ground.
Garrett Sterling /
Thank you for your info Brad.
I tell ya what, Liquid Wrench sure does wonders, forks were rusted and would hardly turn, throttle twist grip was frozen, now it turns, but needs the return spring.
I can't wait till I can have a night to work on it some more.
Main things I need are a highway patrol VIN inspection so I can get a 3 year reg. Some tubes and tires, but what a fun project!
<3 ciaos
I've got 2 of em.
Mike Hojnowski /
On my ciao deluxe, the lever on the headlight turns it on and off. Removing the lever by pulling it up and out is the kill switch - it's like a key.
My ciao has a blue and gray wire for the tail light. They are for brake and running light, respectively. I had to ground to frame to hook up my tail light, as I only had the two wires. YMMV with a different model of ciao.
Hojo
Pull de-comp to kill.
