How do I wire around the taillight/ignition circuit so it will run with out the taillight being an issue. '79 Moron/V1. Been running great until now but it's the tail light circuit being intermittent alright (at least I'm pretty sure). :^)
Ok this taillight/ig. circuit is pissing me off
Re: Ok this taillight/ig. circuit is pissing me off
Change the brake lever switches from normally open to normally closed. Wire them up to your main lighting circuit then ground the old wire. Be sure that the switches are wired in parallel instead of series.
Thanks - I'll give it a shot
