Best bang for the buck would be a pipe and upjet.
If your set on kitting while its apart than look into the olympia kit. I believe it bolts up with out even port matching.. I've heard good things about Dr kits also, as far as having little prep work.. I'm on my 2nd polini kit. I'm happy with it, but there was a fair amount of prep work.
If you get a kit, you "should" get a new crank aswell(I didn't). Or at least have a needle bearing pressed in the stock crank to do away with the brass bushing.
You will need a temp gauge aswell!
Chamfer your port windows, make actual gaskets(using the stencils that come with the kit), check your ring gap ect...
and dont forget, research!!
