Will an E50 flywheel work on a ZA50?
Michael Thomas /
Huh?
Other than the arrows, is there a difference in the magnetic poles or the points lobe?
It is still on the workbench and I was able to set the points at 18 degrees at TDC so not sure. Not like I can check for spark or try and start it.
Thought I would post it here and see if anybody knows.
Thanks
Re: Will an E50 flywheel work on a ZA50?
Overpriced Parts /
No not good if at all in stock position
if you turn it 180 degrees its no real good either
See the steep part of the point cam lobe that snaps open the points is on a different side then on a e50
Michael Thomas /
Thanks Ken...was afraid of that.
