I bought a bing carb off mopedjunkyard.com to replace my previous leaky one. When i went to go upjet to compensate for my high air flow filter and i discovered the atomizer and the jet piece are one. I nearly stripped the jet in the process. It looks like the only option is to buy a new atomizer but treatland is the only place im finding it. http://www.treatland.tv/bing-atomizer-p/bing-atomizer-215.htm... it seems to be the same one i have according to the comment below. Where can i buy an atomizer that allows me to change out the jets?
MopedJunkyard Carb, Upjetting Problem
Re: MopedJunkyard Carb, Upjetting Problem
12mm bing 1.5-2hp take a #222 atomizer
14mm bing 1.5-2hp take a#222 atomizer
15mm bing take a #217 atomizer
17mm bing from a magnum x takes a #215 atomizer
The atomizers treats have now are aftermarket and arn't quite the same jetting
So buy the correct one from bing directly
The atomizer and the jet are not one piece put a 6mm or 7mm wrench on the hex part of the atomizer and then use a flat screw driver to separate the jet.
