A35 I think it's the clutch
So my bike vibrates like crazzy at different times and I think it's the clutch. Could it be because I need new bearing or do you think the clutch is warped?
Re: A35 I think it's the clutch
Hi. Well considering the circumstance you have, it sounds like the clutch it warped. if it was a bearing, then you would have a grinding sound at certian points where the balls inside of the casting are crushed or partly stuck.
One or more of your engine mounting bolts might be loose..chain may be to tight/loose..sprocket could be funky too..
