So my 70cc freshly kitted 505 1-a is giving me nothing but head aches in the clutch area.
Low down, bought and installed ob1 stiffer doughnut spring. Also have swapped stock fiber disk's for metal kevlar clutch pads. The clearence in the stack is very close to stock, still within the preload limits.
Problem. Installed the clutch following the numbered diagrams in the wiki. When the nut is hand tight everything operated as normal. Clutch bell spins freely when the pedals turn, But as soon as i get any sort of torque on the nut, the clutch locks up. Stops spinning freely with the pedal shaft. and wants to turn the engine over without the clutch lever even hooked up. Tried with and without shims, stock and kevlar disks, confussed...
