back fire and stall
would to much oil in my crank case cause my moped to backfire and stall or could it be the carb and choke cleaner I sprayed on the cylinder to find a leak,witch I didnt see.????????????
Re: back fire and stall
♣Slew Foot♣ /
blown seal behind your stator plate could be a real good guess but not knowing make, model
could be the points are worn or coroded or oil deposited, mal adjusted timing too retarded or advanced. clogged exhaust port, bad fuel flow
