It doesn't fit! :(
I bought a Sachs front sprocket for my 504/C. The Sprocket is 12T but the middle area isn't big enough to fit on where my sprocket is. Should I grind it down?
https://www.treatland.tv/front-sprocket-for-sachs-p/mystery-front-sprocket.htm
Re: It doesn't fit! :(
remember, anything past the stock 11T sprocket will not fit unless you grind down the case a bit!!!
I'm not talking about the case though. I'm talking about the inner of the sprocket. It isn't as wide as the stock and won't fit onto my ped.
you have to enlarge the slot then, file it?
File.
Easy.
♣Slew Foot♣ /
that's what she said, Lol
drill, grind, dremel.
