concord running hot?
Hey peders, my moped is running way to hot 1978 concord with a minarelli. I have soldered the magneto wires and adjusted the timing to specs, any suggestions, what causes it to run so hot, also how do i find head or fuel gasget leaks? my piston ring install went flawless guys. thanks all
Jack
Re: concord running hot?
You can try spraying carb cleaner on your head and look for bubbles/getting sucked in.
Probably Fred /
What timing specs did you use?
You can retard timing for cooler running
Jack Johnson /
I have gap set to .015 at tdc,24 degrees, per repair manual. and I have tried it with the stator plate all the way to the left and then all the way to the right, seems a little cooler when I turned it to the right but it still burns up my plugs with in a few miles. I am going out to check for leaks now.
I did solder my wires on the magneto since they were all disconnected. maybe this will tell you something, but when I use my horn my lights cut out.
grrr
running but not well in Holland MI
Jack Johnson /
I don't see any bubbles with the carb cleaner when its runing. I wish that was the prob, I will rent a pressure gauge from auto zone this weekend to really find out, any tips using a screw on pressure gauge. vroom vroom
