CEV coil and boot.
Bought a new NGK boot and wire. But I cant figure out how to get the old boot and wire out, Any tips or do I need a whole new coil?
Re: CEV coil and boot.
try to spin it off counterclockwise, if not just cut it , spin the new one on
if I cut it, There would be some left inside. How would I spin the new one in?
I think the coil and wire are one piece...wire not replaceable.
Then what other coil will wo-... You know what? I'll just go look on Treats. Thanks guys.
If you want to get all crafty you can sometimes shave down the end of the coil, solder on a new cable and seal it up again with some epoxy. Thats kind of a last ditch effort since you can wreck the coil, but I've done it in a pinch.
