Tomos A3 crank pin position question...
Could someone post a picture of the position of the crank pin when the piston is at TDC?
My crank pin is so mangled that I cant tell what the original position was. I am hoping to dremel out the pin, sand it down, and then get that flywheel good and tight.
Re: Tomos A3 crank pin position question...
here you go
the pin is tiny , only about 3mm long
heres a pic without the pin
Thanks, but what I'm really looking for is the exact location of the pin when the piston is at TDC. I can't tell how to put on my flywheel because my pin is gone and so is the hole to mount it- marred from the flywheel turning on it.
How deep is the hole. I need to bore out a new hole for the pin but I have no idea how deep to make it or how much of the pin is supposed to be exposed when its in.
