Discovery: Garelli Piston Works in Kreidler as Replacement!
Hey All,
Learned earlier today, after spending ALL night swapping engines, that the size 'H' Kreidler cylinder will accept a Garelli stock piston as a replacement-- compression is not as good as the Kreidler original since it is not domed like the Kreider's piston top-- but it works pretty well! Piston dimensions are almost identical.
I will note also, that the size 'D' Kreidler cylinder was too small to house the Garelli piston, sadly.
I've added this and some other info to the Kreidler wikis-- pretty sure I linked everything properly too. :)
Just an FYI! I've been using it all day on my trashed Kreidler cylinder with no issues except a slight loss of 'peppiness'.
Take Care,
~Doug
https://www.treatland.tv/garelli-stock-piston-p/garelli-stock-piston-408201.htm
Re: Discovery: Garelli Piston Works in Kreidler as Replacement!
Doug Wilhelm /
Just an update-- piston is still working good. FYI
cool.
