Hobbit - ugly noise coming from clutch? (w/ video)
clutch noise
Anybody have any idea what's going on? It seems like the Variators are variating fine. If I start taking it apart should I order anything else while it's open? Clutch springs? Which ones? It's stock except for the new mlm pipe.
Re: Hobbit - ugly noise coming from clutch? (w/ video)
Downhill Harvey (OFMC) /
Probably cheaper to get a whole new clutch bell housing, part #1,
http://www.westernhillshondayamaha.com/fiche_section_detail.asp?section=2154467&category=Motorcycles&make=HONDA&year=1980&fveh=125246
there's needle bearings inside the clutch bell housing.
The part called drive face for $98. Should I ugrade the weights and springs at the same time? Any suggestions?
There's a lot of metal dust on the outside of the variator.
best open it up. you'll need a puller first, so order one. Once you have it open, you'll be able to spot the broken spring or broken needle bearing or whatever and make another order.
if the whole drive face needs replaced, put a WTB up on the buy/sell forum before you dump $100 at westernhills.
I ordered one yesterday. Thanks!
