Re: What gives? Jetting? Timing? AV10 VIDEO!!!
NEMA Victor (3 Knees Down) /
I have a 19mm PHBG Del on my AV10, then again, I have a Polini kit...
In my experience, you'll want to be dialed in at about 1.3mm or less. I'm currently at 1.1mm.
A 21mm carb might be overkill but what do I know, I just run a 50cc race bike. I doubt the euro kit and your setup would take full advantage of the 21mm carb.
Leave the CDI in, get it down at or below 1.3mm btdc, open your reeds up, make sure that your intake is meant for two pedals and not four (this will cause you to have no low-end and force you to run a leaner setup), and run 50:1 if you are doing synthetic on your break-in. You will gum up your rings and run hotter doing 32:1 in my experience.
  What gives? Jetting? Timing? AV10 VIDEO!!!Topic by: Adam Pereira Adam Pereira 06/26/12 10:39PM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: Adam Pereira Adam Pereira 06/26/12 11:50PM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: Totally normal JBOT Totally normal JBOT 06/27/12 12:19AM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: Adam Pereira Adam Pereira 06/27/12 01:21AM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: Ed - Dead Possums Ed - Dead Possums 06/27/12 12:56AM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: Rebel Moby Rebel Moby 06/27/12 12:26PM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: Adam Pereira Adam Pereira 06/27/12 02:26PM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: Jake P Jake P 06/27/12 06:56PM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: Adam Pereira Adam Pereira 06/27/12 09:05PM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: Adam Pereira Adam Pereira 06/28/12 10:48AM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: Adam Pereira Adam Pereira 06/28/12 12:11PM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: Adam Pereira Adam Pereira 06/28/12 08:41PM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: Totally normal JBOT Totally normal JBOT 06/28/12 10:36PM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: Adam Pereira Adam Pereira 06/28/12 11:19PM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: Adam Pereira Adam Pereira 06/29/12 03:04PM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: nick s nick s 07/01/12 08:56PM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: Adam Pereira Adam Pereira 07/02/12 01:45PM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: NEMA Victor (3 Knees Down) NEMA Victor (3 Knees Down) 07/02/12 03:26PM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: Adam Pereira Adam Pereira 07/03/12 12:25AM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: NEMA Victor (3 Knees Down) NEMA Victor (3 Knees Down) 07/03/12 11:47AM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: Adam Pereira Adam Pereira 07/03/12 03:22PM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: nick s nick s 07/02/12 09:52PM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: Adam Pereira Adam Pereira 07/03/12 01:08AM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: Adam Pereira Adam Pereira 07/04/12 12:48AM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: Adam Pereira Adam Pereira 07/07/12 04:16PM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: Adam Pereira Adam Pereira 07/07/12 11:18PM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: Adam Pereira Adam Pereira 07/08/12 12:01AM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: Adam Pereira Adam Pereira 07/08/12 08:46AM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: Adam Pereira Adam Pereira 07/08/12 10:47AM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: Adam Pereira Adam Pereira 07/08/12 07:46PM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: zach winkle zach winkle 07/09/12 05:16PM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: Adam Pereira Adam Pereira 07/10/12 01:30AM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: NEMA Victor (3 Knees Down) NEMA Victor (3 Knees Down) 07/10/12 07:56AM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: Adam Pereira Adam Pereira 08/07/12 12:15AM
