What gives? Jetting? Timing? AV10 VIDEO!!!
Adam Pereira /
Ok...so this AV10, 47mm Eurocylindro, 19mm PHBG clone, malossi 2 petals reeds, doppler pipe, treats CDI party with a JOG 90 CDI box and the little red ignition coil treats sells with an NGK 5k resistor cap and an NGK B7HS.....swapped gas out to 32:1 redline...i started playing with jetting today...just the main...the clone jet is unmarked, but was about an 82 or so....I redrilled to about an 84, and then about an 90 or so...I've never had a carb run so bad...like not even close. I looked over the spread sheet...I'm seeing 84 to 106 or so on AV10's and I suppose it seems the Dopplers are jetted a bit higher, but damn...it hardly runs under any load. Well...it starts right up and idles really rich, which I'll deal with later. I ordered a flywheel puller to check timing or pull the CDI and throw my points on it....
Does this sound like ultra lean jetting or a carb flow issue...or timing? or? opinions please...this is literally the farthest a carb has even been from being even remotely close. Check it out and thanks in advance.
  What gives? Jetting? Timing? AV10 VIDEO!!!Topic by: Adam Pereira Adam Pereira 06/26/12 10:39PM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: Adam Pereira Adam Pereira 06/26/12 11:50PM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: Totally normal JBOT Totally normal JBOT 06/27/12 12:19AM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: Adam Pereira Adam Pereira 06/27/12 01:21AM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: Ed - Dead Possums Ed - Dead Possums 06/27/12 12:56AM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: Rebel Moby Rebel Moby 06/27/12 12:26PM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: Adam Pereira Adam Pereira 06/27/12 02:26PM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: Jake P Jake P 06/27/12 06:56PM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: Adam Pereira Adam Pereira 06/27/12 09:05PM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: Adam Pereira Adam Pereira 06/28/12 10:48AM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: Adam Pereira Adam Pereira 06/28/12 12:11PM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: Adam Pereira Adam Pereira 06/28/12 08:41PM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: Totally normal JBOT Totally normal JBOT 06/28/12 10:36PM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: Adam Pereira Adam Pereira 06/28/12 11:19PM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: Adam Pereira Adam Pereira 06/29/12 03:04PM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: nick s nick s 07/01/12 08:56PM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: Adam Pereira Adam Pereira 07/02/12 01:45PM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: NEMA Victor (3 Knees Down) NEMA Victor (3 Knees Down) 07/02/12 03:26PM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: Adam Pereira Adam Pereira 07/03/12 12:25AM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: NEMA Victor (3 Knees Down) NEMA Victor (3 Knees Down) 07/03/12 11:47AM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: Adam Pereira Adam Pereira 07/03/12 03:22PM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: nick s nick s 07/02/12 09:52PM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: Adam Pereira Adam Pereira 07/03/12 01:08AM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: Adam Pereira Adam Pereira 07/04/12 12:48AM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: Adam Pereira Adam Pereira 07/07/12 04:16PM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: Adam Pereira Adam Pereira 07/07/12 11:18PM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: Adam Pereira Adam Pereira 07/08/12 12:01AM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: Adam Pereira Adam Pereira 07/08/12 08:46AM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: Adam Pereira Adam Pereira 07/08/12 10:47AM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: Adam Pereira Adam Pereira 07/08/12 07:46PM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: zach winkle zach winkle 07/09/12 05:16PM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: Adam Pereira Adam Pereira 07/10/12 01:30AM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: NEMA Victor (3 Knees Down) NEMA Victor (3 Knees Down) 07/10/12 07:56AM
  Re: What gives? Jetting? Timing? AV10 VIDEO!!!Re: Adam Pereira Adam Pereira 08/07/12 12:15AM
