e50 head bolt broken - how can i remove it?
Luigi Garzone /
Broke one of my e50 head bolts by over tightening like an idiot. The bolt is stuck in the engine case real good, tried a few different things to remove it but it just won't spin. Any suggestions?
Re: e50 head bolt broken - how can i remove it?
Soak it with pb blaster, warm up the case next to it up with a propane torch, repeat a few times.
Luke “Funkenet” Hosfield /
A good sturdy pair of vice grips should to the trick.
If not maybe you could jb weld a nut onto the stud and wrench it out.
Luigi Garzone /
the jb weld sounds like a good idea, i think i'll try that
I have my doubts. But it won't hurt to try.
Probably Fred /
Vice grips works every time
