Re: are 17x2 tires on 17x1.35 mag rims possible? seating troubles
Saabsonettguy . /
Make sure the tube isn't stuck under the bead on the other side. With only a few psi in the tube pinch the bead and try to get it to even out, and then inflate it. Usually when one side is too low, the other side is too high.
