My 2 speed '78 Kreidler shakes badly as it switches gears.
As I ride along and and get up to speed my Kreidler starts shaking like crazy when it wants to shift gears, and it stops after it gets into gear. Any ideas as to what might be causing this?
Re: My 2 speed '78 Kreidler shakes badly as it switches gears.
Ed - Dead Possums /
I'd like to know if you figure this out. I know a guy with the same issue. I've looked at the engine diagrams and those Kreidlers don't have shifting "pucks" like ZA50s have, so not sure how to solve that.
Marcus,
Email me, I have fixed this and am going to for Boot 2TheHead.
It involves taking off the side engine cover and doing a few things-- I'm tired atm, and have work early in the morning, but email / PM me and I'll help you fix it. :)
~DW
Ed - Dead Possums /
If either of you could post that here it would be more helpful to others. Thanks.
I posted it in the past, try searching. :P I'll do a write-up tomorrow.
Its the shims....it's in the forums..
I'm sure it will be up soon, you'll hafta get shims from mcmastr-carr.
we all did.
It is called kreidler 'shifty-shakes'
the worst when riding doubles and stating up a huge short hill.....arrgh.
::To Fix the Kreidler 'Shaking' Problem::
1. Buy ATF Type-F transmission fluid.
2. Drain the Kreidler transmission-- the plug is on the bottom of the engine, it might be a 18mm or 17mm socket.
3. Take out the screws on the tranny side cover carefully.
4. Remove the tranny cover gasket CAREFULLY-- it is a bitch and a half to make a new one.
5. Remove the shims from the two shafts that stick out (small, thin washers).
6. Buy more shims if necessary (Johnny: Can you link to the McMaster ones? I never found the right size there--
http://www.kreidlerparts.com/scripts/parts_cat.asp?gid=6
(Shims are there, but they come from the Netherlands. I have ordered from them a few days ago, but didn't get an invoice as of yet)
**I have all .1mm shims, I'm not sure if the other thicknesses would be useful**
7. Place two shims on each shaft to start off. (This should be ideal)
8. Put everything back together, without fluid, and start it up. See if the engine will idle with the wheel touching the ground. If not, you have too many shims! Take one out at a time, experiment and see what will let your engine idle. You can safely go around the block if you're careful.
9. This should work! I believe it also depends on the thickness of your tranny cover gasket-- but not by much.
If this doesn't work, find someone who has a spare side cover to try. I get the impression that the bearings in the tranny cover wear out / get loose / misalign after years of use, and thus create the imbalance that causes the engine to shake while shifting. Just my take on it--
There you go. :)
~Doug W.
Ed - Dead Possums /
Thanks!
Marcus Tegtmeier /
Thanks, I will work on this.
good info.
mr. doube could you link us to mcmaster to get those shims?
