whistling noise from engine
i got an smc rexy moped with a jog 3kj type motor tht has a whistling sound from the
engine.
53mm bore kit with brand new piston and rings
41.6mm stroker crank
8.2.1 gears
24 oko
uni filter
krs variator
1500 red center spring
new red clutch springs
phongeer pipe
after 3 days without turning it on. i ran the bike and it just started to make the noise
Much help appreciated.
THANKS
Re: whistling noise from engine
Tyler Jaynes /
Could be your seals. I had a fresh rebuilt motor do that once for a little bit.
