Re: No spark but I got a light
Glenn Kuehn /
multimeter on the wire feeding from the stator to the HT coil.
you should be seeing voltage spikes (firing)
if not, something is grounding spark, points, kill, horn, condensor.
ohming that wire with the points open, expect 1 - 2 ohms (stator coil resistance).
points closed, should be close to 0 ohms to case ground.
