Bent flywheel
I removed the flywheel on my general 5 star and went to put it back on. Well now it's bent. Is there anyway to repair this. If not where can I get a new one.
Re: Bent flywheel
Probably Fred /
Woodruff key not centered ?
Or did you beat the flywheel off and not use a puller ?
Re: Bent flywheel
Matt Thurber /
I used a 3 jaw puller, as someone suggested. It wasnt bent before, but it is now. Not really sure how it bent. Just wondering what options I have now.
Re: Bent flywheel
Probably Fred /
There you go You used the wrong puller. See now you learned something that a proper flywheel remover can only be used .
Post for a used flywheel on buy sell and buy a correct tool on treats
Re: Bent flywheel
ブロック 666 /
Use a flywheel puller next time and buy a new flywheel the only fix I see.
