no spark
rebuilt a puch maxi with e50. no spark wiped inside flywheel with finger wow dirt,grim and oil.checked spark and had it.i figured i should clean it with a rag did that and now no spark. what could be issue?
Re: no spark
Downhill Harvey (OFMC) /
WHY
Re: no spark
♣Slew Foot♣ /
pointset grounding against a coil, or coil grounding on flywheel, ht coil grounded to killswitch, broken horn.
Re: no spark
update.pushed open point and tried again,got spark then lost it.pushed open point again and got spark now but its weak and comes and goes help
Re: no spark
Patrick Keaton /
File the top and bottom contacts on the breaker points with an emory board finger nail file. Look at the top and bottom contacts of the breaker points in bright light, to see if you did a good job. Make sure the breaker points contacts are clean when you are done.
