1977 puch maxi will only idle with pipe off
I bought a puch maxi s about two weeks ago. Everything seems good, but I can't get it to idle. I just a performance pipe and it will not idle with it either. When the throttle is fully open, it boggs down. When I was switching pipes, I started it without a pipe and it idled fine with no problems. The jet is a 62. I'm not sure if that would have anything to do with it and I put a hi air flo filter on it. Thanks for any help or suggestions!!
Re: 1977 puch maxi will only idle with pipe off
Probably Fred /
You got to get a aftermarket pipe like a techno circuit .
Stock pipe is junk even unclogged . It's only there to make you go slow.
More air in = more air out . 2 stroke engines need a expandsion chamber pipe like aftermarket ones.
Don't waste your time trying to unclog it cause it's so restrictive you will never get it jetted correctly/run right
Luke “Funkenet” Hosfield /
Read his post, he has a performance pipe.
Probably Fred /
Oh ya it's hard go see all the print on this small screen
Anyway upjet to like 66# jet if you got a 2 hp cylinder, 12 mm carb with # 222 atomizer.
If you got a 1hp well you got to swap out your cylinder
