No idle speed on my Peugeot 102?
I have a Peugeot 102 and i didn't have idle speed.
I clean the carburetor, it was not very dirty, i check the the compression cold i have 145Psi and the exhaust is very clean.
The moped start very easy, the idle screw it screw at the max and i didn't have a idle, i need to keep the gas to keep the motor run.
Something i forget to check?
Thank's (edited)
Re: No idle speed on my Peugeot 102?
Is there a decompression valve on a 102? the valve on my 103 likes to come loose and when it does it maintains enough compression to run but wont idle.
Alain L. /
I check and it's ok.
Is it possible is the timming?
I clean again the carburetor, clean all the gaz tank, the fuel valve and the sparkplug. It start very easy but no idle again...?
