joe karam Wrote:
> And again, it's not working..
> https://www.mopedarmy.com/forums/read.php?7,2747740
> ,page=2
> In that thread, it explains clearly that the
> starter plate should be below. so the cone shim
> would rest on the shlouder on the crankshaft and
> not the clutch.
Joe, I'm glad you found my post and realized it was the same problem I was having. I just wish that 1977 and Treats would realize this and contact the manufacturer to fix the issue.
Deadped Ryan Wrote:
> You could also try grinding the top of the starter
> plate bell/second speed drive gear/second speed
> clutch mount plate and second speed
This is what I have done on the cranks that have had this issue. You must grind down the splines of the starter plate and usually you have to grind down the three "cheeks" near the inside of the second gear clutch so that it has some play on the crankshaft after the cone washer is tight on the crankshaft shoulder.
If anyone has more questions about this or what I have wrote, send me an email or PM and I'll try to respond on here.
