Re: ZA50 rebuild
Deadped Ryan /
You could also try grinding the top of the starter plate bell/second speed drive gear/second speed clutch mount plate and second speed gear to lower it so that shoulder is exposed, but then you're decreasing the surface area of the second speed clutch splines.
Or, you could try and make an additional spacer that fits inside the starter clutch bushing to make a new shoulder for the cone to rest on.
My question is, if you stack your cone washer or whatever you're calling it - the spacer that goes between first and second clutch - on top of the second clutch, then first speed clutch, then lock tab and then thread the nut on without the nut going above the bottom of the brash bushing on the bottom of the crank... If you can't then you're going to need even more clearance and certainly not going to be able to come up with just a spacer.
I'd just chalk this up to experience and eat the $150 or however much the crank was and not ruin the rest of your motor and work.
  ZA50 rebuildTopic by: joe karam joe karam 06/20/12 01:47AM
  Re: ZA50 rebuildRe: Mo Peds Mo Peds 06/20/12 09:18AM
  Re: ZA50 rebuildRe: Michael Thomas Michael Thomas 06/20/12 09:41AM
  Re: ZA50 rebuildRe: Miss Tammiecat~ Miss Tammiecat~ 06/20/12 11:44AM
  Re: ZA50 rebuildRe: Michael Thomas Michael Thomas 06/20/12 03:54PM
  Re: ZA50 rebuildRe: Miss Tammiecat~ Miss Tammiecat~ 06/21/12 10:27AM
  Re: ZA50 rebuildRe: joe karam joe karam 06/20/12 08:22PM
  Re: ZA50 rebuildRe: Probably Fred Probably Fred 06/21/12 11:30AM
  Re: ZA50 rebuildRe: joe karam joe karam 06/21/12 03:59PM
  Re: ZA50 rebuildRe: Probably Fred Probably Fred 06/21/12 04:42PM
  Re: ZA50 rebuildRe: joe karam joe karam 06/21/12 06:02PM
  Re: ZA50 rebuildRe: joe karam joe karam 06/24/12 08:33AM
  Re: ZA50 rebuildRe: Miss Tammiecat~ Miss Tammiecat~ 06/25/12 10:32AM
  Re: ZA50 rebuildRe: joe karam joe karam 06/26/12 09:18AM
  Re: ZA50 rebuildRe: Deadped Ryan Deadped Ryan 06/26/12 09:29AM
  Re: ZA50 rebuildRe: joe karam joe karam 06/28/12 08:43PM
  Re: ZA50 rebuildRe: Deadped Ryan Deadped Ryan 06/28/12 09:56PM
  Re: ZA50 rebuildRe: joe karam joe karam 06/28/12 10:17PM
  Re: ZA50 rebuildRe: Deadped Ryan Deadped Ryan 06/28/12 10:27PM
  Re: ZA50 rebuildRe: Button Rojo Button Rojo 06/26/12 08:01AM
  Re: ZA50 rebuildRe: Deadped Ryan Deadped Ryan 06/26/12 08:22AM
  Re: ZA50 rebuildRe: Deadped Ryan Deadped Ryan 06/26/12 08:33AM
  Re: ZA50 rebuildRe: joe karam joe karam 06/28/12 12:38AM
  Re: ZA50 rebuildRe: Mo Peds Mo Peds 06/28/12 09:48AM
  Re: ZA50 rebuildRe: Deadped Ryan Deadped Ryan 06/28/12 11:01AM
  Re: ZA50 rebuildRe: joe karam joe karam 06/28/12 12:50PM
  Re: ZA50 rebuildRe: joe karam joe karam 06/28/12 03:07PM
  Re: ZA50 rebuildRe: Mo Peds Mo Peds 06/28/12 07:15PM
  Re: ZA50 rebuildRe: Deadped Ryan Deadped Ryan 06/28/12 10:10PM
  Re: ZA50 rebuildRe: Jake P Jake P 07/12/12 08:25PM
  Re: ZA50 rebuildRe: Mo Peds Mo Peds 07/13/12 08:04AM
  Re: ZA50 rebuildRe: joe karam joe karam 06/29/12 02:42AM
  Re: ZA50 rebuildRe: Miss Tammiecat~ Miss Tammiecat~ 06/29/12 10:53AM
  Re: ZA50 rebuildRe: joe karam joe karam 07/10/12 04:41PM
  Re: ZA50 rebuildRe: Miss Tammiecat~ Miss Tammiecat~ 07/10/12 04:53PM
  Re: ZA50 rebuildRe: mit mortso mit mortso 07/13/12 03:27PM
  Re: ZA50 rebuildRe: Ken Mullis Ken Mullis 07/15/12 12:25AM
  Re: ZA50 rebuildRe: Rick Ems Rick Ems 07/15/12 01:22AM
  Re: ZA50 rebuildRe: Mars   Mars   06/26/12 08:21AM
