Re: ZA50 rebuild
Deadped Ryan /
Ok... i get it... you really suck at explaining things lol.
I don't know really how you're going to fix that without recutting that circlip groove on the crank.
If you lower the clutch any on the starter plate bell/second speed drive gear/second speed clutch mount plate - you're going to hit the second speed gear with the pucks in it.
If you drop the starter plate bell/second speed drive gear/second speed clutch mount plate any by grinding the surface that rides on the thrust washer that sits ontop of the circlip, you're going to engage the clutch.
If you recut the groove on the crank, you risk giving the starter plate bell/second speed drive gear/second speed clutch mount plate too much wiggle room and hitting the second speed gear with the pucks that drives the output shaft.
If you leave the circlip out completely, the clutch is going to hit the second speed drive gear with pucks that drives the output shaft or that spring is going to be a loose cannon and do who knows what.
Try assembling it without the circlip and one of the thrust washers... That's the only way I see it working without cutting a new groove. TBH, I wouldn't run anything like that.
I would try to come up with something else besides cutting a new groove, but I can't think of anything right now.
Sometimes the old stuff is the good stuff... Maybe you should just cut your losses and have your old crank rebuilt. You don't want to blow your shit up because it's jank.
I also hope you're not just trying to change the subject because you got your crank to stop binding... If that's jank too, you might as well just strap an M80 to this engine and save yourself the time and trouble. (edited)
  ZA50 rebuildTopic by: joe karam joe karam 06/20/12 01:47AM
  Re: ZA50 rebuildRe: Mo Peds Mo Peds 06/20/12 09:18AM
  Re: ZA50 rebuildRe: Michael Thomas Michael Thomas 06/20/12 09:41AM
  Re: ZA50 rebuildRe: Miss Tammiecat~ Miss Tammiecat~ 06/20/12 11:44AM
  Re: ZA50 rebuildRe: Michael Thomas Michael Thomas 06/20/12 03:54PM
  Re: ZA50 rebuildRe: Miss Tammiecat~ Miss Tammiecat~ 06/21/12 10:27AM
  Re: ZA50 rebuildRe: joe karam joe karam 06/20/12 08:22PM
  Re: ZA50 rebuildRe: Overpriced Parts Overpriced Parts 06/21/12 11:30AM
  Re: ZA50 rebuildRe: joe karam joe karam 06/21/12 03:59PM
  Re: ZA50 rebuildRe: Overpriced Parts Overpriced Parts 06/21/12 04:42PM
  Re: ZA50 rebuildRe: joe karam joe karam 06/21/12 06:02PM
  Re: ZA50 rebuildRe: joe karam joe karam 06/24/12 08:33AM
  Re: ZA50 rebuildRe: Miss Tammiecat~ Miss Tammiecat~ 06/25/12 10:32AM
  Re: ZA50 rebuildRe: joe karam joe karam 06/26/12 09:18AM
  Re: ZA50 rebuildRe: Deadped Ryan Deadped Ryan 06/26/12 09:29AM
  Re: ZA50 rebuildRe: joe karam joe karam 06/28/12 08:43PM
  Re: ZA50 rebuildRe: Deadped Ryan Deadped Ryan 06/28/12 09:56PM
  Re: ZA50 rebuildRe: joe karam joe karam 06/28/12 10:17PM
  Re: ZA50 rebuildRe: Deadped Ryan Deadped Ryan 06/28/12 10:27PM
  Re: ZA50 rebuildRe: Button Rojo Button Rojo 06/26/12 08:01AM
  Re: ZA50 rebuildRe: Deadped Ryan Deadped Ryan 06/26/12 08:22AM
  Re: ZA50 rebuildRe: Deadped Ryan Deadped Ryan 06/26/12 08:33AM
  Re: ZA50 rebuildRe: joe karam joe karam 06/28/12 12:38AM
  Re: ZA50 rebuildRe: Mo Peds Mo Peds 06/28/12 09:48AM
  Re: ZA50 rebuildRe: Deadped Ryan Deadped Ryan 06/28/12 11:01AM
  Re: ZA50 rebuildRe: joe karam joe karam 06/28/12 12:50PM
  Re: ZA50 rebuildRe: joe karam joe karam 06/28/12 03:07PM
  Re: ZA50 rebuildRe: Mo Peds Mo Peds 06/28/12 07:15PM
  Re: ZA50 rebuildRe: Deadped Ryan Deadped Ryan 06/28/12 10:10PM
  Re: ZA50 rebuildRe: Jake P Jake P 07/12/12 08:25PM
  Re: ZA50 rebuildRe: Mo Peds Mo Peds 07/13/12 08:04AM
  Re: ZA50 rebuildRe: joe karam joe karam 06/29/12 02:42AM
  Re: ZA50 rebuildRe: Miss Tammiecat~ Miss Tammiecat~ 06/29/12 10:53AM
  Re: ZA50 rebuildRe: joe karam joe karam 07/10/12 04:41PM
  Re: ZA50 rebuildRe: Miss Tammiecat~ Miss Tammiecat~ 07/10/12 04:53PM
  Re: ZA50 rebuildRe: mit mortso mit mortso 07/13/12 03:27PM
  Re: ZA50 rebuildRe: Ken Mullis Ken Mullis 07/15/12 12:25AM
  Re: ZA50 rebuildRe: Rick Ems Rick Ems 07/15/12 01:22AM
  Re: ZA50 rebuildRe: Mars   Mars   06/26/12 08:21AM
