Re: ZA50 rebuild
Mo Peds /
Don't ever use liquid gasket on a ZA50 engine. These are the most unforegiving engines you have ever seen. The germans build them on a scale of presicion of the up most tolerances. So you need to Measure and Measure and remeasure. The snap ring is 1mm off as when they remade them at nice/rich factory they built. You'll need .1mm shims to correct the starter plate problem. You need to shim the output shaft outside.
Yes, you may have to use a .012 and .004 or 2 .008 to get the correct tolerances/play on the main crankshaft bearings. I only use the brands of sfk or fag bearings. Brand of bearings does matter imo as the design of the bearings have change... the thickness. You need to set the crankshaft to ZERO end play paz stated in one of his posts while back.
Here is some video about things that no one else addresses but me.
  ZA50 rebuildTopic by: joe karam joe karam 06/20/12 01:47AM
  Re: ZA50 rebuildRe: Mo Peds Mo Peds 06/20/12 09:18AM
  Re: ZA50 rebuildRe: Michael Thomas Michael Thomas 06/20/12 09:41AM
  Re: ZA50 rebuildRe: Miss Tammiecat~ Miss Tammiecat~ 06/20/12 11:44AM
  Re: ZA50 rebuildRe: Michael Thomas Michael Thomas 06/20/12 03:54PM
  Re: ZA50 rebuildRe: Miss Tammiecat~ Miss Tammiecat~ 06/21/12 10:27AM
  Re: ZA50 rebuildRe: joe karam joe karam 06/20/12 08:22PM
  Re: ZA50 rebuildRe: Probably Fred Probably Fred 06/21/12 11:30AM
  Re: ZA50 rebuildRe: joe karam joe karam 06/21/12 03:59PM
  Re: ZA50 rebuildRe: Probably Fred Probably Fred 06/21/12 04:42PM
  Re: ZA50 rebuildRe: joe karam joe karam 06/21/12 06:02PM
  Re: ZA50 rebuildRe: joe karam joe karam 06/24/12 08:33AM
  Re: ZA50 rebuildRe: Miss Tammiecat~ Miss Tammiecat~ 06/25/12 10:32AM
  Re: ZA50 rebuildRe: joe karam joe karam 06/26/12 09:18AM
  Re: ZA50 rebuildRe: Deadped Ryan Deadped Ryan 06/26/12 09:29AM
  Re: ZA50 rebuildRe: joe karam joe karam 06/28/12 08:43PM
  Re: ZA50 rebuildRe: Deadped Ryan Deadped Ryan 06/28/12 09:56PM
  Re: ZA50 rebuildRe: joe karam joe karam 06/28/12 10:17PM
  Re: ZA50 rebuildRe: Deadped Ryan Deadped Ryan 06/28/12 10:27PM
  Re: ZA50 rebuildRe: Button Rojo Button Rojo 06/26/12 08:01AM
  Re: ZA50 rebuildRe: Deadped Ryan Deadped Ryan 06/26/12 08:22AM
  Re: ZA50 rebuildRe: Deadped Ryan Deadped Ryan 06/26/12 08:33AM
  Re: ZA50 rebuildRe: joe karam joe karam 06/28/12 12:38AM
  Re: ZA50 rebuildRe: Mo Peds Mo Peds 06/28/12 09:48AM
  Re: ZA50 rebuildRe: Deadped Ryan Deadped Ryan 06/28/12 11:01AM
  Re: ZA50 rebuildRe: joe karam joe karam 06/28/12 12:50PM
  Re: ZA50 rebuildRe: joe karam joe karam 06/28/12 03:07PM
  Re: ZA50 rebuildRe: Mo Peds Mo Peds 06/28/12 07:15PM
  Re: ZA50 rebuildRe: Deadped Ryan Deadped Ryan 06/28/12 10:10PM
  Re: ZA50 rebuildRe: Jake P Jake P 07/12/12 08:25PM
  Re: ZA50 rebuildRe: Mo Peds Mo Peds 07/13/12 08:04AM
  Re: ZA50 rebuildRe: joe karam joe karam 06/29/12 02:42AM
  Re: ZA50 rebuildRe: Miss Tammiecat~ Miss Tammiecat~ 06/29/12 10:53AM
  Re: ZA50 rebuildRe: joe karam joe karam 07/10/12 04:41PM
  Re: ZA50 rebuildRe: Miss Tammiecat~ Miss Tammiecat~ 07/10/12 04:53PM
  Re: ZA50 rebuildRe: mit mortso mit mortso 07/13/12 03:27PM
  Re: ZA50 rebuildRe: Ken Mullis Ken Mullis 07/15/12 12:25AM
  Re: ZA50 rebuildRe: Rick Ems Rick Ems 07/15/12 01:22AM
  Re: ZA50 rebuildRe: Mars   Mars   06/26/12 08:21AM
