The races are fine I guess, Theyre further than ''flush'' with the case halves.
But I'll try to remove them and measure them...
My original case gasket looks fine, maybe it is 0,04mm thicker.. I can't imagine how 0,04mm can change anything when I tighten everything but the mystery of mopeds is far beyond from science.....
On treatland, they sell the 0,08 and 0,12mm case gasket. I thought it would make a difference with the and float only and couldn't affect the bearing binding as soon as I assemble the case halves.... I have the 0,08m gasket, maybe that's the problem.
