Re: ZA50 rebuild
Miss Tammiecat~ /
I'm assuming you put new seals in, which will cause a little bit of stick but not so much you cant turn the crank by hand.
make sure your seals are pressed in properly, and that your bearings races and cup are pressed in evenly and completely.
As Ed said, new bearings must go with their new races/ cups
also, are you re-using or using new crankcase gasket?
it might also help to assemble the case halves in the orientation it would be when mounted to the bike...
there is a large amount of info on MA about this rebuild, you should be able to find your problem and solution on here by digging in some forum threads. bottom line, if it doesnt feel right, its not.
take it apart and do it again.
  ZA50 rebuildTopic by: joe karam joe karam 06/20/12 01:47AM
  Re: ZA50 rebuildRe: Mo Peds Mo Peds 06/20/12 09:18AM
  Re: ZA50 rebuildRe: Michael Thomas Michael Thomas 06/20/12 09:41AM
  Re: ZA50 rebuildRe: Miss Tammiecat~ Miss Tammiecat~ 06/20/12 11:44AM
  Re: ZA50 rebuildRe: Michael Thomas Michael Thomas 06/20/12 03:54PM
  Re: ZA50 rebuildRe: Miss Tammiecat~ Miss Tammiecat~ 06/21/12 10:27AM
  Re: ZA50 rebuildRe: joe karam joe karam 06/20/12 08:22PM
  Re: ZA50 rebuildRe: Probably Fred Probably Fred 06/21/12 11:30AM
  Re: ZA50 rebuildRe: joe karam joe karam 06/21/12 03:59PM
  Re: ZA50 rebuildRe: Probably Fred Probably Fred 06/21/12 04:42PM
  Re: ZA50 rebuildRe: joe karam joe karam 06/21/12 06:02PM
  Re: ZA50 rebuildRe: joe karam joe karam 06/24/12 08:33AM
  Re: ZA50 rebuildRe: Miss Tammiecat~ Miss Tammiecat~ 06/25/12 10:32AM
  Re: ZA50 rebuildRe: joe karam joe karam 06/26/12 09:18AM
  Re: ZA50 rebuildRe: Deadped Ryan Deadped Ryan 06/26/12 09:29AM
  Re: ZA50 rebuildRe: joe karam joe karam 06/28/12 08:43PM
  Re: ZA50 rebuildRe: Deadped Ryan Deadped Ryan 06/28/12 09:56PM
  Re: ZA50 rebuildRe: joe karam joe karam 06/28/12 10:17PM
  Re: ZA50 rebuildRe: Deadped Ryan Deadped Ryan 06/28/12 10:27PM
  Re: ZA50 rebuildRe: Button Rojo Button Rojo 06/26/12 08:01AM
  Re: ZA50 rebuildRe: Deadped Ryan Deadped Ryan 06/26/12 08:22AM
  Re: ZA50 rebuildRe: Deadped Ryan Deadped Ryan 06/26/12 08:33AM
  Re: ZA50 rebuildRe: joe karam joe karam 06/28/12 12:38AM
  Re: ZA50 rebuildRe: Mo Peds Mo Peds 06/28/12 09:48AM
  Re: ZA50 rebuildRe: Deadped Ryan Deadped Ryan 06/28/12 11:01AM
  Re: ZA50 rebuildRe: joe karam joe karam 06/28/12 12:50PM
  Re: ZA50 rebuildRe: joe karam joe karam 06/28/12 03:07PM
  Re: ZA50 rebuildRe: Mo Peds Mo Peds 06/28/12 07:15PM
  Re: ZA50 rebuildRe: Deadped Ryan Deadped Ryan 06/28/12 10:10PM
  Re: ZA50 rebuildRe: Jake P Jake P 07/12/12 08:25PM
  Re: ZA50 rebuildRe: Mo Peds Mo Peds 07/13/12 08:04AM
  Re: ZA50 rebuildRe: joe karam joe karam 06/29/12 02:42AM
  Re: ZA50 rebuildRe: Miss Tammiecat~ Miss Tammiecat~ 06/29/12 10:53AM
  Re: ZA50 rebuildRe: joe karam joe karam 07/10/12 04:41PM
  Re: ZA50 rebuildRe: Miss Tammiecat~ Miss Tammiecat~ 07/10/12 04:53PM
  Re: ZA50 rebuildRe: mit mortso mit mortso 07/13/12 03:27PM
  Re: ZA50 rebuildRe: Ken Mullis Ken Mullis 07/15/12 12:25AM
  Re: ZA50 rebuildRe: Rick Ems Rick Ems 07/15/12 01:22AM
  Re: ZA50 rebuildRe: Mars   Mars   06/26/12 08:21AM
