Regulator / Rectifier
So here's the deal... usual lights blowing stuff on a maxi. The stator gives out 6v - 15v. I'm on LED's so I've got a 12v with 1v - 2v tolerance, which means I get blown bulbs sporadically...
If I put a 12v regulator / rectifier, will it work variably up until it reaches the 12v, or will it just not work at all and only work when the stator gives 12 or above?
hmmm....any thoughts?
Re: Regulator / Rectifier
12 regulator. use it.
there's also the trailtech adjustable ones, that's a sweet optiion.
