Re: Sachs tranny oil
Born to be WillD /
you can use almost any oil really, typically folks'll use ATF transmission fluid or SAE 30 oil. Non detergent is a better option, detergent oils are made for 4 strokes where the oil lubricates the cylinder also. Best stuff is motorcycle or scooter transmission oils.
you take the plug out and fill it til it comes out the hole, you may have to refill it after running it a little because it takes some going to slosh it all around in there properly.
