Tomos Questions
Hello,
I am new to MA. I picked up a Tomos Bullet and I was wondering if I could get some help with a few questions I had.
I am trying to figure out what model/year the engine is as I do not think I have the original engine that came on this bike. The number stamped on the engine is 902722 and the bike itself has a VIN of Y2A01117DK 386086
I am trying to get it running but there are some minor parts holding me from moving forward. It has a Dellorto SHA 1515 carb on it.
At this point i'd just like to get it running and then possibly get a 70cc build kit for it.
Any help would be greatly appreciated.
Re: Tomos Questions
post a picture and we will tell you everything. the year should be listed on the vin plate on the fork tube.
Re: Tomos Questions
The only thing is that the motor doesn't match the frame VIN. I believe it is an '83 (seeing that the 5/83) is stamped in the upper right of the VIN plate.
The only information I really need at this point is what model my engine is. I have attached a photo. Again, the numbers stamped on the engine are:
902722
Re: Tomos Questions
> plate.
> are:
> 902722
If you look on the head, its stamped Tomos A5, but it doesn't look like the A5 engine. It looks more like the A35 kick start.
Re: Tomos Questions
You have an A35 Kickstart, with what looks to be a airsal 70cc cylinder installed. Someone has likely swapped a newer motor onto the older frame. Post a photo of the whole bike if you can.
Re: Tomos Questions
Here is the whole bike. That would be nice to know if its the 70cc cylinder already on there.
Re: Tomos Questions
Ok, that is an 80's tomos for sure, with an early to mid 90's a35 motor. A very nice combination. The aluminum cylinder indicates that it is aftermarket. Its very likely that it is the 70cc (65cc technically) airsal. It should be pretty quick once you get those two missing motor mount bolts installed and get it going.
Re: Tomos Questions
Tptwo Tptwotwo /
sure ya right on okay
