Re: points arching at every rpm
Rebel Moby /
Get new set of points if the cam follower is or may be worn down. The follower is the plastic or phenolic part which rides on the cam.
Get a VW or mid1960 GM 6 cylinder condenser (Standard DR60) and mount it external to the genny and clip the old wire to the old condenser. Splice the new condenser into the wire going from points to ignition coil.
