Re: Spun, how do you fix?
Rebel Moby /
Run a die over it to go undersize and use a new nut and a wave washer. You could also make anchor holes in flywheel and nut and use lockwire and she will never spin off unless you cut the wire first. 1977mopeds sells wire pliers and lockwire
