Batavus no idle, please help
My batavus is finally running but won't keep running. After I start her shell cut out if the throttle is closed. What gives?
Re: Batavus no idle, please help
♣Slew Foot♣ /
okay so you got the throttle cable ran,
the clutch is not sticking any more it can freespin right? after thoose issues are resolved take the adjuster on the handle in most of the way so it is really low but there is tension and no slack in it.
then this is where it gets tricky, keep it running on the stand, and while holding the brake, line up the hole in the pulley to the idle screw on the carb, turn it in until it speeds up to an aceptable idle. careful not to lose a finger it can speed up and break away.
