Moby transmission options.
I just bought an av10 case, and I can't find enough information online to make a solid decision. I don't want a clutch pulley. Do I NEED to have a kickstart to use just a normal pulley? I want pegs, doppler er3, and normal pulley. Is this possible?
Re: Moby transmission options.
yepperz. get the er3 WITH clutch function and use cardboard to start it. you dont need kickstart. (edited)
Pull start
Arsenio Braga /
I'm new to the french realm, Puchs are specialty. I'm not sure what you mean by using cardboard to start it, and how does the pull start work with a variator?
Wrap an belt or piece of sash cord around the flywheel and pull.
Piece of cardboard or popsicle stick to wedge the pully to start, the moment it catches the cardboard or stick will be flung away.
Pull Start :)
Arsenio Braga /
Ok, I was thinking it was more like the puch hpi pull starts. Im pushing starting my puch now, theoretically could I also push start this Moby?
