PUCH CYLINDER DEATH NOISE HELP
Davis Vasconcellos /
ok so really bad sounding problem, i REALLY need help on this. put a new throttle cable for my puch and whenever i go to accelerate the cylinder starts making a really loud popping noise and stops accelerating, like repetitive popping, i had it running fine for about a day. ill put up a video tomorrow so you can see/hear what i mean. any ideas welcome, again, i REALLY REALLY need this fixed. mopeds are annoying as fuck.
Re: PUCH CYLINDER DEATH NOISE HELP
Patrick Keaton /
Common problem that you may have is the connecting rod bushing where the piston connects is wore.You may have to remove it and replace it to solve the proble.Most of the time, this does not hurt accelerating, it just a nuisance of a noise.Look at the thread Dreamboat started about popcorn for more info.
So, before replacing the throttle cable, it was fine, and after replacing the cable it started doing this? Nothing else changed, and it only began to do it this after the replacement?
