Re: 50V Moby no spark or lights and decompressor question
Kyle Osborne /
Rebel Moby Wrote:
> You have two wires then it is not a 6v it is a
> 6/12v, look on the back of the genny and see on
> the black connector 6v and 12v.
> 12v two internal coil you must have the 12v either
> in contact with the common or have an accessory
> running on the wire which is in contact with
> common.
> Disconnect everything from the genny and
> disconnect anything from the gray wire going to
> the external coil. Connect a jumper from the 12v
> terminal on the back of the genny and attach the
> other end to one of the intake studs.
> Run a bonding strap from the intake stud up to the
> lower stud on the external coil.
> Attach the gray wire to the external coil with no
> other wire attached to it.
> Check for spark
> If you have no spark get a Standard DR60 or
> equivalent condenser from a car parts store or
> online. Mount the condenser to the lower external
> coil stud where you attached the bonding strap.
> Splice the pigtail from the condenser to the gray
> wire.
> Disconnect the original condenser from the
> points.
> Clean the points with a points file (or metal
> finger nail file) and flush them with alcohol or
> brake cleaner (not carb cleaner).
> Check for spark.
also, what do you mean by "intake stud" and "lower stud"?
I"m assuming Lower stud means one of the bolts holding the ign coil onto the frame? Or is it something else?
and do I need to take the cover off to do this?
  50V Moby no spark or lights and decompressor questionTopic by: Kyle Osborne Kyle Osborne 06/12/12 09:07PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Ian Grant Ian Grant 06/12/12 10:08PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Kyle Osborne Kyle Osborne 06/13/12 01:54PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Michael Koerber Michael Koerber 06/13/12 07:46PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Rebel Moby Rebel Moby 06/12/12 10:30PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Kyle Osborne Kyle Osborne 06/12/12 10:36PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Kyle Osborne Kyle Osborne 06/13/12 02:00PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Kyle Osborne Kyle Osborne 06/12/12 10:31PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Kyle Osborne Kyle Osborne 06/20/12 03:27PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Rebel Moby Rebel Moby 06/12/12 10:39PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Kyle Osborne Kyle Osborne 06/12/12 11:51PM
  Re: 50V Moby no spark or lights and decompressor questionRe: ♣Slew Foot♣ ♣Slew Foot♣ 06/13/12 02:26AM
  Re: 50V Moby no spark or lights and decompressor questionRe: Rebel Moby Rebel Moby 06/13/12 08:51AM
  Re: 50V Moby no spark or lights and decompressor questionRe: Rebel Moby Rebel Moby 06/13/12 04:54PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Kyle Osborne Kyle Osborne 06/14/12 12:18AM
  Re: 50V Moby no spark or lights and decompressor questionRe: Rebel Moby Rebel Moby 06/20/12 06:10PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Kyle Osborne Kyle Osborne 06/20/12 06:37PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Rebel Moby Rebel Moby 06/20/12 10:34PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Kyle Osborne Kyle Osborne 06/21/12 02:07AM
  Re: 50V Moby no spark or lights and decompressor questionRe: Kyle Osborne Kyle Osborne 06/21/12 01:29PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Stephen Keller Stephen Keller 06/21/12 03:15AM
  Re: 50V Moby no spark or lights and decompressor questionRe: Rebel Moby Rebel Moby 06/21/12 08:49AM
  Re: 50V Moby no spark or lights and decompressor questionRe: Kyle Osborne Kyle Osborne 08/25/12 12:15AM
  Re: 50V Moby no spark or lights and decompressor questionRe: Kyle Osborne Kyle Osborne 08/25/12 06:06PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Rebel Moby Rebel Moby 08/25/12 09:11PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Kyle Osborne Kyle Osborne 08/25/12 09:42PM
