Re: 50V Moby no spark or lights and decompressor question
Kyle Osborne /
Rebel Moby Wrote:
> You have two wires then it is not a 6v it is a
> 6/12v, look on the back of the genny and see on
> the black connector 6v and 12v.
> 12v two internal coil you must have the 12v either
> in contact with the common or have an accessory
> running on the wire which is in contact with
> common.
> Disconnect everything from the genny and
> disconnect anything from the gray wire going to
> the external coil. Connect a jumper from the 12v
> terminal on the back of the genny and attach the
> other end to one of the intake studs.
> Run a bonding strap from the intake stud up to the
> lower stud on the external coil.
> Attach the gray wire to the external coil with no
> other wire attached to it.
> Check for spark
> If you have no spark get a Standard DR60 or
> equivalent condenser from a car parts store or
> online. Mount the condenser to the lower external
> coil stud where you attached the bonding strap.
> Splice the pigtail from the condenser to the gray
> wire.
> Disconnect the original condenser from the
> points.
> Clean the points with a points file (or metal
> finger nail file) and flush them with alcohol or
> brake cleaner (not carb cleaner).
> Check for spark.
Ahh, ok so that could be why it's not working, I was troubleshooting it as if it were a straight 6v.....I"ll give this a shot tomorrow. Thanks!
  50V Moby no spark or lights and decompressor questionTopic by: Kyle Osborne Kyle Osborne 06/12/12 09:07PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Ian Grant Ian Grant 06/12/12 10:08PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Kyle Osborne Kyle Osborne 06/13/12 01:54PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Michael Koerber Michael Koerber 06/13/12 07:46PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Rebel Moby Rebel Moby 06/12/12 10:30PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Kyle Osborne Kyle Osborne 06/12/12 10:36PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Kyle Osborne Kyle Osborne 06/13/12 02:00PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Kyle Osborne Kyle Osborne 06/12/12 10:31PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Kyle Osborne Kyle Osborne 06/20/12 03:27PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Rebel Moby Rebel Moby 06/12/12 10:39PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Kyle Osborne Kyle Osborne 06/12/12 11:51PM
  Re: 50V Moby no spark or lights and decompressor questionRe: ♣Slew Foot♣ ♣Slew Foot♣ 06/13/12 02:26AM
  Re: 50V Moby no spark or lights and decompressor questionRe: Rebel Moby Rebel Moby 06/13/12 08:51AM
  Re: 50V Moby no spark or lights and decompressor questionRe: Rebel Moby Rebel Moby 06/13/12 04:54PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Kyle Osborne Kyle Osborne 06/14/12 12:18AM
  Re: 50V Moby no spark or lights and decompressor questionRe: Rebel Moby Rebel Moby 06/20/12 06:10PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Kyle Osborne Kyle Osborne 06/20/12 06:37PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Rebel Moby Rebel Moby 06/20/12 10:34PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Kyle Osborne Kyle Osborne 06/21/12 02:07AM
  Re: 50V Moby no spark or lights and decompressor questionRe: Kyle Osborne Kyle Osborne 06/21/12 01:29PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Stephen Keller Stephen Keller 06/21/12 03:15AM
  Re: 50V Moby no spark or lights and decompressor questionRe: Rebel Moby Rebel Moby 06/21/12 08:49AM
  Re: 50V Moby no spark or lights and decompressor questionRe: Kyle Osborne Kyle Osborne 08/25/12 12:15AM
  Re: 50V Moby no spark or lights and decompressor questionRe: Kyle Osborne Kyle Osborne 08/25/12 06:06PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Rebel Moby Rebel Moby 08/25/12 09:11PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Kyle Osborne Kyle Osborne 08/25/12 09:42PM
