Re: 50V Moby no spark or lights and decompressor question
Kyle Osborne /
Rebel Moby Wrote:
> Look on the back of the genny - single spade
> terminal=6volt, black plastic with two
> terminals=6/12volt.
> 6 volt will run with no accessories attached, you
> just need the gray wire from the genny to the
> external coil. but you better fix the decompressor
> or you have to shut her down by pulling the plug
> wire.
> 6/12volt with three coils inside the genny will
> run with accessories disconnected
> 6/12volt with two coils inside the genny needs to
> have an accessory attached to the 12 volt or that
> terminal grounded because it is the other end of
> the winding for the ignition coil.
> Is the spark robust and snappy or yellowy and
> weak? Might need to change out the condenser,
> Get a 1960s GM 6 cylinder condenser and mount it
> beside the external coil. Disconnect the old one
> inside the genny and connect the pigtail from the
> new one to the gray wire.
> Make sure you have a good bonding strap between
> the external coil and one of the intake studs.
there's 3 wires from the genny, a brown and a black one and the grey one that goes to the coil..and it has 2 coils inside...and looking at the wiring diagram again, I"m guessing that's what i need to do, is ground the black wire, from the ignition coil.
Thanks.
  50V Moby no spark or lights and decompressor questionTopic by: Kyle Osborne Kyle Osborne 06/12/12 09:07PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Ian Grant Ian Grant 06/12/12 10:08PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Kyle Osborne Kyle Osborne 06/13/12 01:54PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Michael Koerber Michael Koerber 06/13/12 07:46PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Rebel Moby Rebel Moby 06/12/12 10:30PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Kyle Osborne Kyle Osborne 06/12/12 10:36PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Kyle Osborne Kyle Osborne 06/13/12 02:00PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Kyle Osborne Kyle Osborne 06/12/12 10:31PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Kyle Osborne Kyle Osborne 06/20/12 03:27PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Rebel Moby Rebel Moby 06/12/12 10:39PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Kyle Osborne Kyle Osborne 06/12/12 11:51PM
  Re: 50V Moby no spark or lights and decompressor questionRe: ♣Slew Foot♣ ♣Slew Foot♣ 06/13/12 02:26AM
  Re: 50V Moby no spark or lights and decompressor questionRe: Rebel Moby Rebel Moby 06/13/12 08:51AM
  Re: 50V Moby no spark or lights and decompressor questionRe: Rebel Moby Rebel Moby 06/13/12 04:54PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Kyle Osborne Kyle Osborne 06/14/12 12:18AM
  Re: 50V Moby no spark or lights and decompressor questionRe: Rebel Moby Rebel Moby 06/20/12 06:10PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Kyle Osborne Kyle Osborne 06/20/12 06:37PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Rebel Moby Rebel Moby 06/20/12 10:34PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Kyle Osborne Kyle Osborne 06/21/12 02:07AM
  Re: 50V Moby no spark or lights and decompressor questionRe: Kyle Osborne Kyle Osborne 06/21/12 01:29PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Stephen Keller Stephen Keller 06/21/12 03:15AM
  Re: 50V Moby no spark or lights and decompressor questionRe: Rebel Moby Rebel Moby 06/21/12 08:49AM
  Re: 50V Moby no spark or lights and decompressor questionRe: Kyle Osborne Kyle Osborne 08/25/12 12:15AM
  Re: 50V Moby no spark or lights and decompressor questionRe: Kyle Osborne Kyle Osborne 08/25/12 06:06PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Rebel Moby Rebel Moby 08/25/12 09:11PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Kyle Osborne Kyle Osborne 08/25/12 09:42PM
