Re: 50V Moby no spark or lights and decompressor question
Rebel Moby /
Look on the back of the genny - single spade terminal=6volt, black plastic with two terminals=6/12volt.
6 volt will run with no accessories attached, you just need the gray wire from the genny to the external coil. but you better fix the decompressor or you have to shut her down by pulling the plug wire.
6/12volt with three coils inside the genny will run with accessories disconnected
6/12volt with two coils inside the genny needs to have an accessory attached to the 12 volt or that terminal grounded because it is the other end of the winding for the ignition coil.
Is the spark robust and snappy or yellowy and weak? Might need to change out the condenser, Get a 1960s GM 6 cylinder condenser and mount it beside the external coil. Disconnect the old one inside the genny and connect the pigtail from the new one to the gray wire.
Make sure you have a good bonding strap between the external coil and one of the intake studs.
  50V Moby no spark or lights and decompressor questionTopic by: Kyle Osborne Kyle Osborne 06/12/12 09:07PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Ian Grant Ian Grant 06/12/12 10:08PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Kyle Osborne Kyle Osborne 06/13/12 01:54PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Michael Koerber Michael Koerber 06/13/12 07:46PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Rebel Moby Rebel Moby 06/12/12 10:30PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Kyle Osborne Kyle Osborne 06/12/12 10:36PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Kyle Osborne Kyle Osborne 06/13/12 02:00PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Kyle Osborne Kyle Osborne 06/12/12 10:31PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Kyle Osborne Kyle Osborne 06/20/12 03:27PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Rebel Moby Rebel Moby 06/12/12 10:39PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Kyle Osborne Kyle Osborne 06/12/12 11:51PM
  Re: 50V Moby no spark or lights and decompressor questionRe: ♣Slew Foot♣ ♣Slew Foot♣ 06/13/12 02:26AM
  Re: 50V Moby no spark or lights and decompressor questionRe: Rebel Moby Rebel Moby 06/13/12 08:51AM
  Re: 50V Moby no spark or lights and decompressor questionRe: Rebel Moby Rebel Moby 06/13/12 04:54PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Kyle Osborne Kyle Osborne 06/14/12 12:18AM
  Re: 50V Moby no spark or lights and decompressor questionRe: Rebel Moby Rebel Moby 06/20/12 06:10PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Kyle Osborne Kyle Osborne 06/20/12 06:37PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Rebel Moby Rebel Moby 06/20/12 10:34PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Kyle Osborne Kyle Osborne 06/21/12 02:07AM
  Re: 50V Moby no spark or lights and decompressor questionRe: Kyle Osborne Kyle Osborne 06/21/12 01:29PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Stephen Keller Stephen Keller 06/21/12 03:15AM
  Re: 50V Moby no spark or lights and decompressor questionRe: Rebel Moby Rebel Moby 06/21/12 08:49AM
  Re: 50V Moby no spark or lights and decompressor questionRe: Kyle Osborne Kyle Osborne 08/25/12 12:15AM
  Re: 50V Moby no spark or lights and decompressor questionRe: Kyle Osborne Kyle Osborne 08/25/12 06:06PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Rebel Moby Rebel Moby 08/25/12 09:11PM
  Re: 50V Moby no spark or lights and decompressor questionRe: Kyle Osborne Kyle Osborne 08/25/12 09:42PM
