qt50 rear gear
hello, i need a little help with swapping out the gears in my qt50 and putting in pw50 gears to make it a little fast. can anyone help me with what i all need to put and how i would go about putting in the new gears. thanks
Re: qt50 rear gear
you gotta take the stock splined QT axle and press it into the pw50 gear to hook up the PW's housing on the qt.
see also: http://forums.everything2stroke.com/showthread.php?t=39121
Re: qt50 rear gear
i have a friend that was talking about this, and i may be wrong, but im pretty sure the shaft lengths are different, so you need to have an adapter made.
