Vespa Grande points
Can someone explain how I get to the points/condenser on a grande?
Re: Vespa Grande points
If you have some small pliers, a screwdriver, and a steady hand you can get the points out through the access hole in the flywheel. Otherwise you'll have to take the engine out of the frame and take off the flywheel.
Steve Diedrich /
If you want to adjust the points, you are supposed to be able to do that thru the hole in the flywheel. If you actually want to get to them you have to pull the flywheel.
