E50 3-shoe clutch randomly not dis-engaging
Luke “Funkenet” Hosfield /
So like once out of 20-30 times that I come to a stop my clutch isn't disengaging. It can go all the way to a dead stop without the clutch letting go of the bell.
Obviously it won't idle like that so it stalls. An easy way to fix it is to roll the back tire back and forth and it will come loose.
What would cause this?
Re: E50 3-shoe clutch randomly not dis-engaging
Salsa Salsa /
Bent posts
Why does it happen only rarely then?
Probably Fred /
Or starter clutch problem/ too tight adjusted
I doubt it but its worth checking anyway.
Probably Fred /
I had a starter clutch plate bad bearing that caused same kind of problems cause then I over tightened the clutch. The spec is at the lever min 1/2 inch play
I had one where the spring holes in the center section were drilled crooked, causing the spring to hang up sometimes. Check your holes and either dremel them straight or get a new clutch base.
Hadn't though of that jake. New clutch base is coming they're so cheap I should've got two.
