Re: kstar base gasket?
Dale Myers /
most high revving engines will need to have there clutches tuned for more slip. to get past the shitty running rev areas. just to get it up to the power band. i worked on a chain saw that had a seized clutch bearing. and wouldn't even run. once i changed the bearing. it ran like it should. that would be the equivalent to having a stock clutch on a race ped.
